kcomiami
Aug 14, 2020Follower
Trouble connecting Samsung TV to RAX120
As the title mentions I am having trouble connecting my Samsung TV to the router due to passkey settings not being compatible with the TV. I was wondering if maybe I am doing this wrong? I dont broadcast my SSID, so WPS isn't an option. Maybe someone can help me finding the correct combo? I have no problem using a different encryption method.
Samsung TV Passkey options:
OPEN
WEP
WPA2PSK (AES)
WPA2/WPA Mixed PSK
Nighthawk RAX120 - Router Firmware 1.0.1.128
Passkey Options
NONE
WPA2-Personal (AES)
WPA-Personal (TKIP) + WPA2-Personal (AES)
WPA/WPA2 Enterprise
WPA3-Personal
WPA-2Personal (AES) + WPA3 Personal
I'm not sure if the TV is just saying one of these differently upto this point I havent figured out a combo that works?
1 Reply
- Christian_RNETGEAR Employee Retired
Hi kcomiami,
If you recently purchased the device, you may want to reach out to our support team. Newly purchased devices are provided with 90 days if complimentary support.
https://www.netgear.com/support/default.aspx
Christian
