Dustin_V
Apr 30, 2019NETGEAR Employee Retired
Troubleshooting - Windows Device Not Detecting AX Router's WiFi Network
 If your Windows device is not detecting your AX router’s wireless network, you might have an older Intel (R) wireless network adapter (some older Intel adapters include: Intel Dual Band Wireless AC-3...
schumaku
Apr 30, 2019Guru - Experienced User
The most easy way to load the Intel® driver updates:
You can load most Intel® driver updates using the Intel® Driver and Support Assistant (Intel® DSA), which will:
- Detect your machine’s configuration.
 - Identify your current Intel® drivers.
 - Notify you of any drivers that need updating.
 - Give you the opportunity to update those drivers.
