LdBzinski's avatar
Feb 18, 2021
Trying to connect to Starlink Dish on different subnet
I have a Netgear Nighthawk RAX70 connected to the Starlink dish (instead of the provided router which, if I can get this working, isn't necessary.) Others have been successful using their own routers but they are different makes and models.
My router's IP address is 192.168.10.1. The Starlink dish's IP address is 192.168.100.1
On the Starlink forum they tell you to create a static route with a gateway of 0.0.0.0 but that is not an accepted gateway on this device. They also mention using the dish's address as the gateway which also doesn't work.
With over 10,000 subscribers now, I would think that someone with this router would have figured this out. If you have it working, could you please tell me how you did it? It would be much appreciated. Thank you!
  • Looks like my screenshot from my last post didn't work so here's the info you need.
    First, find your Gateway IP Address by clicking on the Advanced tab then click Advanced Home. On the right side of your window you will see "Internet Port". Scroll down to the IP Address. It will look similar to the following: 100.66.106.142
    Create a Static Route with the following:
    Give it a name such as: Starlink Dish
    Destination IP Address: 192.168.100.0
    IP Subnet Mask: 255.255.255.0
    Gateway IP Address: (that you looked up)
    Metric: 2   (if 2 doesn't work, try 3 or 5)
    You're welcome!
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello LdBzinski,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
    • LdBzinski's avatar
      LdBzinski
      Guide
      Well that's too funny! I've been emailing back and forth to support and they have been absolutely useless.I explaned the issue in minute detail. No help at all to make any kind of configuration changes on the Netgear router. They told me: You need to bypass the router, connect a computer using ethernet cable directly on the modem and access modem default IP address which is 192.168.100.1.
      So much for the $500 router and Netgear support! Totally frustrated and disappointed. I will never buy Netgear again!!!
      • antinode's avatar
        antinode
        Guru
        > (instead of the provided router [...]
           The non-psychics in your audience might know very little about your
        (unspecified) "the Starlink dish" or your (unspecified) "the provided
        router" or its (invisible) configuration.
        > [...] The Starlink dish's IP address is 192.168.100.1
           Perhaps it is, but that's not obvious.  A DOCSIS cable modem also
        responds at that address, but it has little significance to the user's
        network.
           If you connect the RAX70 to it, what does the RAX70 get as the IP
        address for its WAN/Internet interface? (ADVANCED > ADVANCED Home :
        Internet Port : Internet IP Address)
        > On the Starlink forum [...]
           Thanks for the helpful link.
        > [...] I explaned the issue in minute detail. [...]
           If you provided them the same kind of "minute detail" as you provided
        here, then I would not be amazed if you got no useful response.
           My guess would be that when you said "192.168.100.1", they heard
        "cable modem", and followed their script.
           Another example of a poor problem description:
              https://community.netgear.com/t5/x/x/m-p/2044964
