Scoves
Jan 18, 2021Aspirant
Trying to setup Kasa smart plugs and my nighthawk modem kicks off all wifi to my house(told try here
I have the nighthawk model RAX35. I just obtained some Kasa Smart WIFI Plug Lite HS103's. When I try to set them up to my internet so they can be used my wifi goes down. The Modem disconnects all wifi and will not turn it back on. I have to unplug the Kasa Smart plug to get it to start my wifi back up. Something is going on between the modem and the Kasa smart plugs. I tried working with Kasa but they said it is not on their end. That it is on the Netgears modem end. Which stinks for me becuase I am a few months out of warranty to get support. Which makes it almost cheaper to go out and by a whole new modem instead perhaps not a netgear one at that. I am wondering before I do all that if anyone has had similar issues and had them resolved? Or would know why this occurs. I have set up another brand of smart plug and it works fine along with other wifi items I use but for some reason the kasa ones disagree with my modem. Thank you for any help.
Firmware version by the way for my modem is v1.0.3.62_1.0.1
I solved the issue finally. I was able to update my firmware and it fixed the issue.
- ScovesAspirant
- Christian_RNETGEAR Employee Retired
Hello Scoves,
Thanks for providing an update to your post as it may possibly help others in the future.
Regards,Christian
