brado77
Nov 29, 2022Star
Trying to understand nature of "DoS attack: RST Scan" log messages
Disclaimer: I am a security engineer, so my questions which follow are not to understand what a DoS attack or RST scan are; I know what those are -- I'm trying to understand the behavior of my router...
microchip8
Nov 30, 2022Master
NETGEAR routers are famosly known for generating false DoS entries, even from your local devices. 98% of these can be discarded as they're false positives. It's a broken system. If you suspect an entry is valid, you can look up its IP. NG also reports attacks from your own devices and ISP. I wouldn't trust that system ever, unless they completely fix/rewrite it.
As these DoS attacks slow down the router by requiring processing (blocking) and logging, it's best to either disable logging or if that is not enough completely disable DoS protection - you're not missing much. I run 8 years without DoS protection and have yet to experience something disturbing/malicious/etc
