brado77
Nov 29, 2022Star
Trying to understand nature of "DoS attack: RST Scan" log messages
Disclaimer: I am a security engineer, so my questions which follow are not to understand what a DoS attack or RST scan are; I know what those are -- I'm trying to understand the behavior of my router...
michaelkenward
Nov 30, 2022Guru - Experienced User
brado77 wrote:
Disclaimer: I am a security engineer, so my questions which follow are not to understand what a DoS attack or RST scan are; I know what those are -- I'm trying to understand the behavior of my router and the nature of its logging.
microchip8 sums it up. Their answer should warn you that you are on a hopeless quest in trying to understand how your router behaves. That's because there doesn't seem to be any logic in there that you can fathom.
As things stand, as a security engineer you can probably tell us more than most about what is going on under the hood.
- brado77Nov 30, 2022Star
michaelkenward thanks for the reply.
Well, what I know is that something here doesn’t make sense, The meaning of the log entry isn’t clear nor is the criteria which generates it; even if you knew all of that information, there doesn’t appear to be any mitigation options in the router for the likely possibilities. It kind of relegates all of the supposed security features to Christmas lights — they blink and flash and look pretty and makes you feel good that they’re there, but they don’t have much of a pragmatic use. (No knock on Christmas lights).
Improving usability surrounding logs, diagnostics, and documentation on low-level routing function would all be pretty low-hanging fruit to give these routers a giant leap forward. Seems like NETGEAR wants to follow the model of newer cars, sealed black boxes which you cannot fully administer and work on yourself. Too bad, much room for improvement here. Kind of screams for a Raspberry Pi Kickstarter.
Anyway, thx again for the response.
- michaelkenwardDec 01, 2022Guru - Experienced User
The issue of weird logs has been rattling around here for some time. Hence the boilerplate repose "check the sort of those attacks".
As to "it would be easy to fix" comments, I bow to your knowledge, but in many cases these demands come from people who don't know what it takes to code this sort of stuff. They also overlook the fact that coding is just a part of it. Qualification of the new firmware – getting it through quality control and the like – is probably more complicated than the coding. And as we see all too often, when broken firmware lands here, it is this bit of the process that fails.
But please keep digging. This has turned into an interesting conversation.
- microchip8Dec 01, 2022Master
Fact is, NG refuses to change the developer of its firmware (NG itself doesn't make the firmware) most likely due to economic issues. I'm absolutely sure NG is aware it has one of the worst firmware around, yet refuses to do anything. Delta Networks, inc (DNI) doesn't care that much as long as they get paid and offer a "good enough" firmware, regardless of bugs and other issues
If NG continues this path and doesn't change its priorities, they will fall further and further down.
That said, NG offers one of the best *hardware* devices around. They run cool, are very solid and reliable, and just work (unless the firmware throws crap)
