Retired_Member
Sep 20, 2022Trying to use wifi6e on RAX 50
Now I have an iPhone 14 pro which should support this protocol. It seems as though I need WPA3 and I have a ton of older Ring, Chamberlain, Hue, computers and tablets that won't support WPA3. If I se...
- Sep 20, 2022
If you have other devices that don't support WPA3 then you'll need to keep with WPA2 and AES. I don't know if this model has a mixed WPA2 and WPA3 setting.
6E is a 6Ghz frequency which this model router doesn't support.
Sep 20, 2022Guru - Experienced User
The RAX50 doesn't support 6E only 6.
Did you find security mode settings under Basic tab/Wireless settings?
Retired_Member
Sep 20, 2022Yes I see those settings but I do now want to lose all of my devices that cannot use that protocol. I have it set to enable AX though.
- FURRYe38Sep 20, 2022Guru - Experienced User
- Retired_MemberSep 20, 2022
So assuming I need WPA3 to connect to AX I am out of luck so to speak.
No, AX works on WPA2 or WPA3.
Ya no mixed mode WPA2 and WPA3 so you'll need to keep with WPA2. Or find you a router that supports mixed modes.
