Retired_Member
Sep 20, 2022Trying to use wifi6e on RAX 50
Now I have an iPhone 14 pro which should support this protocol. It seems as though I need WPA3 and I have a ton of older Ring, Chamberlain, Hue, computers and tablets that won't support WPA3. If I se...
- Sep 20, 2022
If you have other devices that don't support WPA3 then you'll need to keep with WPA2 and AES. I don't know if this model has a mixed WPA2 and WPA3 setting.
6E is a 6Ghz frequency which this model router doesn't support.
Retired_Member
Sep 20, 2022Yes I see those settings but I do now want to lose all of my devices that cannot use that protocol. I have it set to enable AX though.
Sep 20, 2022Guru - Experienced User
- Retired_MemberSep 20, 2022
So assuming I need WPA3 to connect to AX I am out of luck so to speak.
- FURRYe38Sep 20, 2022Guru - Experienced User
No, AX works on WPA2 or WPA3.
Ya no mixed mode WPA2 and WPA3 so you'll need to keep with WPA2. Or find you a router that supports mixed modes.
- Retired_MemberSep 21, 2022
And now that I know this new phone doesn't support 6e as well, I should be satisfied with my 225 meg download speed. Since I have 1gig speed here I was looking for more. I am hesitant about any mesh system because of ODNT* So I will wait for next years iPhone upgrade and see where that takes me.
* ODNT (you can't teach an old dog new tricks)
