jaymz69
May 07, 2021Apprentice
Turn Off Armor
Model not showing up in dropdown: it is MR60 Mesh Nighthawk with satilites. I go into te app and turn off the Armor for security BUT it always not matter how many times I try, what day or time it is,...
May 07, 2021Guru - Experienced User
Have you tried a simple factory reset and reinstall?
What modem/gateway are you connected to?
jaymz69
I really did not want to do the whole factory reset thing. I just got ths last september. I am connected to a SurfBoard Gig using xfinity as the ISP.
- plemansMay 08, 2021Guru - Experienced User
What arris surfboard? They make a few.
You might not want to reset but it might be key in helping troubleshoot your issue.
You could try a reinstall of the firmware without the reset to see if it helps.
You could also try uninstalling the app and reinstalling the app in cases its an app issue. Or try a different device
