LitteGratz
Nov 05, 2021Aspirant
Turn the CAX80 into a Modem only
CAX80 - Nighthawk® AX8/8-Stream WiFi 6 Cable Modem Router How do I set it up the CAX8 as just a Modem? My House is just to big and I want to do a Mesh Wifi system. Thanks, Rob
Nov 05, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Look for Router Mode under the Advanced tab/Advanced settings page. Set it to NO.
Thank you.
