SForsgren
Aug 02, 2021Follower
Turning off armor
I am getting a url blocked and I unblock it in the app but still doesn’t work.
If I need to get to a site that Netgear is blocking, can I turn off the feature that is blocking it?
Seems odd that unblocking in the app still doesn’t seem to work.
Thanks for any insights.
1 Reply
- slackrlLuminary
Hello SForsgren
You might try
1. Rebooting the router.
2. While the router is down reboot the device the app is on.
3. If that does not work try turn the feature off at the router with a web browser.
by logging in to the router, use routerlogin.com or routerlogin.net.
slackrl
