ctclone3211
Jul 26, 2019Tutor
two bands and one SSID with Password
The back of the router indicated a SSID and Password. Do I use the same for both bands?
- Jul 26, 2019
Sorry misunderstood what you where asking previsouly,
Abosolutly you can keep the bands seperate and your can create unique SSID's aswell as unique or seperate passwords for each band :)
Josh_R
Jul 26, 2019Tutor
As long as you have enabled Smart Connect under the wirless settings on the router you will be able use both bands and one password and SSID. It will use the default network SSID and password details if you have not changed them.
ctclone3211
Jul 26, 2019Tutor
I would rather not use Smart Connect. Once I get access to the unit on the web, will I be then able to change to whatever I want for either band?
- Josh_RJul 26, 2019Tutor
- ctclone3211Jul 26, 2019Tutor
Thanks for the reply. That is what I thought and just wanted to be clear.
