jmcguire7869
Sep 22, 2021Follower
Two ISP connections RAXE800
Our business network has one simple file server, the nighthawk router and WOW as the ISP. My boss would like a failover set for another ISP. Is this possible with the Nighthawk, or even if the first...
Sep 22, 2021Guru - Experienced User
No.
None of the consumer routers have dual wan capability from netgear.
A couple have LTE capability for failover. Where you can have LTE and a wan connection.
And some of the business devices have dual wan capability.
there are dual wan capable routers you can buy and then connect the RAX200 to it but put the rax in access point mode to prevent double nat issues.
