JimTurkey
Sep 23, 2021Guide
Two Nighthawk AX5400 (RAX50) routers in one house? U-Verse related!
Our house is in the shape of a capital "L". Our U-Verse BGW210 is located at the small end of the "L". Our bedroom & office are located at the big end of the "L". As a result, our wi-fi reception is ...
JimTurkey
Sep 24, 2021Guide
From what I have read, there is no difference really between the RBK753 and RBK753, right?
By the way, you've been a huge help. Thank you.
Sep 24, 2021Guru - Experienced User
JimTurkey wrote:
From what I have read, there is no difference really between the RBK753 and RBK753, right?----well since they're the same models.....unless you mistyped.
- plemansSep 24, 2021Guru - Experienced User
Same thing except the S version has Armor included for a certain period of time.
