maarkr
Nov 17, 2021Aspirant
Two reservations?
unit is actually a rax48 AX6 ax5200 but wasn't in the menu... updated the firmware yesterday. trying to reserve two addresses for my cameras that are assigned to an ip address in iSpy software, so...
Nov 17, 2021Guru - Experienced User
What happens if you add 1 IP address reservation, APPLY the setting, then REBOOT the router. Then go back in and try to add another IP address reservation for the other camera?
