cullen1jim
May 30, 2019Aspirant
Two routers on one network netgear setup
Do i need two routers. i have a nighthawk and the wrn1000 that came with my home security system?
cullen1jim
May 31, 2019Aspirant
Thank you for your help. i need help doing any of the things you recomend.
michaelkenward
Jun 01, 2019Guru - Experienced User
What make is the home security system?
How does it connect to your WNR1000 router? Wifi? Wired LAN?
