gryffyn's avatar
gryffyn
Initiate
Jan 29, 2024
Two routers, same network segment.. configuration help
Pretty basic network configuration: Comcast/Xfinity coax into the house -> Xfinity cable modem (first network) ->  RAX10 router on the other side of the house (wired, <100ft) to provide additional ...
  • FURRYe38's avatar
    Jan 29, 2024
    Cant have two routers on same segment using same IPs, one has to be different IP addressing.
    Or configured the RAX for AP Mode and use it for its wireless abilities only.
