syrock
Jan 09, 2022Guide
Unable to Access Advanced Tab in Routerlogin Portal After Firmware Update
Hello, Router Model: RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router Previous Firmware: 1.0.2.82 (released January 2021) Current Firmware: 1.0.5.106 (released December 2021) Situation: I ...
Jan 09, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
- FoundtonyJan 29, 2022Tutor
I'm using Apple iPad Pro with the RAX45 Nighthawk router, just purchased at Costco. . After using Duck-Duck-Go to manually perform the firmware upgrade to V1.0.5.106 I was not able to access the Advanced Tab using Safari or Duck-Duck-Go. However, on my MacBook Pro I can access the Advanced Tab using Google Chrome.
