syrock
Jan 10, 2022Guide
Unable to Access Advanced Tab in Routerlogin Portal After Firmware Update
 Hello,     Router Model: RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router  Previous Firmware: 1.0.2.82 (released January 2021)  Current Firmware: 1.0.5.106 (released December 2021)     Situation: I ...
JJM55
Jan 12, 2022Aspirant
Advance tab stopped working after update.
Jan 12, 2022Guru - Experienced User
- amonynutsJan 12, 2022ApprenticeUnder the Basic tab, I can click on Home, Internet, etc, and these menu items work. The Nighthawk app also works, but I need to configure many more settings than are available in the app. Using Firefox on a laptop, the mouse pointer switches from an arrow to a hand when I hover over the word Advanced, but there is no response when I click it. Interestingly enough I was able to go into the Advanced menu once on my iPhone and assumed it started working so I started configuring and one of the first thing I did was to enable HTTPS, and then the Advanced tab immediately stopped working again. Router model RAX45-100NAS Nighthawk AX6 AX4300 Firmware V1.0.6.106_2.0.70 - FURRYe38Jan 12, 2022Guru - Experienced UserAfter enabling HTTPs for Web Managment Services, did you clear out the browser cache the exit the brower the re-load the browser then use HTTPS to enter the routers web page?
 amonynuts wrote:
 Under the Basic tab, I can click on Home, Internet, etc, and these menu items work. The Nighthawk app also works, but I need to configure many more settings than are available in the app. Using Firefox on a laptop, the mouse pointer switches from an arrow to a hand when I hover over the word Advanced, but there is no response when I click it. Interestingly enough I was able to go into the Advanced menu once on my iPhone and assumed it started working so I started configuring and one of the first thing I did was to enable HTTPS, and then the Advanced tab immediately stopped working again. Router model RAX45-100NAS Nighthawk AX6 AX4300 Firmware V1.0.6.106_2.0.70 - amonynutsJan 12, 2022ApprenticeI tried that. Clearing the browser's cache, even using a different computer, did not help. I suppose there's no URL that I can enter to bypass the JavaScript & access the Advanced options directly...
