syrock
Jan 10, 2022Guide
Unable to Access Advanced Tab in Routerlogin Portal After Firmware Update
 Hello,     Router Model: RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router  Previous Firmware: 1.0.2.82 (released January 2021)  Current Firmware: 1.0.5.106 (released December 2021)     Situation: I ...
Bruce10
Jan 13, 2022Aspirant
I have same problem on RAX43: unable to access "advance" tab after manual update to latest firmwear. I wanted Advance tab to enable automatic firmwear updates. Hope Netgear can fix their problem soon.
- FURRYe38Jan 13, 2022Guru - Experienced UserBe sure to contact NG support and let them know. - TwitchrotJan 21, 2022StarMate this is rubbish. You can't log a job if you don't have a current support contract and most of these issues are effecting people who have had these routers for over a year or more and probably don't have a current support contract. It is a good way to get extra cash out of people but if this is Netgear's new business model then I'm not sure you will succeed in the long term. Why would someone take out an extended support contract when its over half the price of a new router. Advice to factory reset a device and start again is akin to asking "have your turned it off and on again. That won't fix poor change management practices, sloppy coding resulting in interface problems introduced between router firmware upgrades.
