syrock
Jan 10, 2022Guide
Unable to Access Advanced Tab in Routerlogin Portal After Firmware Update
 Hello,     Router Model: RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router  Previous Firmware: 1.0.2.82 (released January 2021)  Current Firmware: 1.0.5.106 (released December 2021)     Situation: I ...
G35flyer
Jan 21, 2022Star
I found a workaround. Once connected to the routers Basic web interface type any junk behind your rounter url....for example: https://192.168.1.1/junk
You will get a 404 error, then hit the broswer back button and you can then gain access to the Advanced settings.
