syrock
Jan 10, 2022Guide
Unable to Access Advanced Tab in Routerlogin Portal After Firmware Update
 Hello,     Router Model: RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router  Previous Firmware: 1.0.2.82 (released January 2021)  Current Firmware: 1.0.5.106 (released December 2021)     Situation: I ...
Foundtony
Jan 29, 2022Tutor
Router model: AX6 RAX45 Nighthawk
I'm using Apple iPad Pro with the AX6 RAX45 Nighthawk router, just purchased at Costco. . After using Duck-Duck-Go to manually perform the firmware upgrade to V1.0.5.106 I was not able to access the Advanced Tab using Safari or Duck-Duck-Go. However, on my MacBook Pro I can access the Advanced Tab using Google Chrome.
syrock wrote:Hello,
Situation: I am unable to click the advanced tab when accessing the routerlogin portal through multiple browsers.
Background: I noticed my 5GHz connection was dropping wifi signal occassionally while 2.4GHz was still operational. The 5GHz would return after a few minutes without the need to reboot the router. This issue became more frequent, prompting me to check I have the most up to date software. I logged into the routerlogin portal and went to advanced settings to review my firmware version. I had previously selected to auto-update firmware when setting up the router, which did not appear to be working since I was still on 1.0.2.82 (released January 2021). I checked for updates and found a new version was available (1.0.5.106; released December 2021). I tried to use the internal portal program to update the software but kept receiving a GUI failure message. Instead, I opted to download the firmware file to my laptop and update manually. The download completed successfully and my wifi is working without issue. However, now I am unable to click the advanced settings tab on the routerlogin page. This means I can no longer access advanced settings to manually adjust wifi channels or check for new firmware updates. I logged into the routerlogin portal from multiple devices using different browsers (macbook pro safari, iphone safari, and windows 10 microsoft edge) and all have the same issue. I attached a screenshot of my homepage for reference.
Primary Assessment: It appears there is a bug not allowing users to click the advanced tab within the routerlogin portal.
Secondary Assessment: It appears the auto-update firmware feature does not work appropriately.
Has anyone else experienced this? Any thoughts on how to fix this? Is it a possible bug in the new firmware?
Andrew
DarrenM
Feb 03, 2022Sr. NETGEAR Moderator
We have trial firmware with a fix for this issue please send me a PM if you would like to try this firmware.
DarrenM
- lpayne-elliottFeb 14, 2022AspirantModel RAX 45
 I would appreciate the trial firmware to fix the “advanced” tab issue.- FURRYe38Feb 15, 2022Guru - Experienced UserPlease contact the forum moderator about this:
 lpayne-elliott wrote:
 Model RAX 45
 I would appreciate the trial firmware to fix the “advanced” tab issue.- syrockFeb 18, 2022Guide
 FURRYe38 wrote:Please contact the forum moderator about this:
 Model RAX 45
 I would appreciate the trial firmware to fix the “advanced” tab issue.I contacted Darren via private message and have yet to hear back.
- ThawktogoMar 01, 2022AspirantWould like to test upgrade firmware
- micbt25Mar 09, 2022Aspirant
 DarrenM wrote:We have trial firmware with a fix for this issue please send me a PM if you would like to try this firmware. DarrenM When will it be rolled out, this has been going on entirely too long. - FURRYe38Mar 09, 2022Guru - Experienced UserNG doesn't post that information. You'll have to keep an eye on NG support download page or here in the forums. If you want to try the beta, send DarrenM a PM Thank you.
 micbt25 wrote:
 DarrenM wrote:
 We have trial firmware with a fix for this issue please send me a PM if you would like to try this firmware. DarrenM When will it be rolled out, this has been going on entirely too long. - micbt25Mar 11, 2022Aspirant
 FURRYe38 wrote:NG doesn't post that information. You'll have to keep an eye on NG support download page or here in the forums. If you want to try the beta, send DarrenM a PM Thank you.
 micbt25 wrote:
 DarrenM wrote:We have trial firmware with a fix for this issue please send me a PM if you would like to try this firmware. DarrenM When will it be rolled out, this has been going on entirely too long. Nevermind, this thing is going back to Costco. In 2 decades I've never had issues with new routers as I do with this one. In addition to the administration issues with not being able to view the advanced tab, the connection to the Internet drops off and I isolated that issue to the router not the 5g access point.
