syrock
Jan 10, 2022Guide
Unable to Access Advanced Tab in Routerlogin Portal After Firmware Update
 Hello,     Router Model: RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router  Previous Firmware: 1.0.2.82 (released January 2021)  Current Firmware: 1.0.5.106 (released December 2021)     Situation: I ...
Foundtony
Feb 17, 2022Tutor
What kind of device are you connecting through, a PC, tablet, laptop? I upgraded my AXE45 and had the same issue with the advanced tab. I discovered I couldn’t access advanced tab on my iPad Pro with any browser, but I could on my MacBook Pro using Google Chrome.
- syrockFeb 18, 2022Guide
 Foundtony wrote:
 What kind of device are you connecting through, a PC, tablet, laptop? I upgraded my AXE45 and had the same issue with the advanced tab. I discovered I couldn’t access advanced tab on my iPad Pro with any browser, but I could on my MacBook Pro using Google Chrome.I did find I can use chrome on my MacBook Pro to access the advanced tab. Still a larger issue with safari users. Hopefully Netgear is working on a permanent fix.
