syrock
Jan 10, 2022Guide
Unable to Access Advanced Tab in Routerlogin Portal After Firmware Update
Hello, Router Model: RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router Previous Firmware: 1.0.2.82 (released January 2021) Current Firmware: 1.0.5.106 (released December 2021) Situation: I ...
DarrenM
Feb 03, 2022Sr. NETGEAR Moderator
We have trial firmware with a fix for this issue please send me a PM if you would like to try this firmware.
DarrenM
micbt25
Mar 09, 2022Aspirant
DarrenM wrote:We have trial firmware with a fix for this issue please send me a PM if you would like to try this firmware.
DarrenM
When will it be rolled out, this has been going on entirely too long.
- FURRYe38Mar 09, 2022Guru - Experienced User
NG doesn't post that information. You'll have to keep an eye on NG support download page or here in the forums.
If you want to try the beta, send DarrenM a PM
Thank you.
micbt25 wrote:
DarrenM
- micbt25Mar 11, 2022Aspirant
FURRYe38 wrote:NG doesn't post that information. You'll have to keep an eye on NG support download page or here in the forums.
Thank you.
DarrenM
Nevermind, this thing is going back to Costco. In 2 decades I've never had issues with new routers as I do with this one. In addition to the administration issues with not being able to view the advanced tab, the connection to the Internet drops off and I isolated that issue to the router not the 5g access point.
- DarrenMMar 16, 2022Sr. NETGEAR Moderator
Please send me a PM if you would like to try Beta firmware that has a fix for this issue.
DarrenM
