LorneDmitruk
May 12, 2021Aspirant
Unable to Change 5g WiFi Channel on RAX*)
Hi, I have a RAX80, firmware V1.0.3.106_1.0.50, Region Canada and it will not let me change the 5G channel from 44 to anything else. Channel 36 + 40 + 44(P) + 48 Mode Up to 24...
LorneDmitruk
Here's the screen shot of the channel picklist.
Christian_R
May 17, 2021NETGEAR Employee Retired
Hello LorneDmitruk,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- LorneDmitrukMay 21, 2021Aspirant
Hi,
Unfortunately I purchased my unit in January and it is out of the 90 day support window.
