MightyMouse423
Aug 16, 2020Follower
Unable to change SSID and password
Hi, I am currently trying to change my SSID and password on my AX4 router but every time I try to apply the settings, it shows the loading bar as if it is going to chnage just to load and show the ol...
Christian_R
Aug 21, 2020NETGEAR Employee Retired
Hi MightMouse423,
May you revert back to the previous firmware version and let us know if your issue persists.
Christian
- khleeAug 21, 2020Aspiranti cant change time zone, my ssid, password..
everytime i changed, click apply, processing bar moving, after finished, nothing happened.. - khleeAug 21, 2020Aspirantwhat is the previous firmware, where to download
- Christian_RAug 27, 2020NETGEAR Employee Retired
khlee,
Please refer to the article below and on step 5, you may select previous firmware versions to manually revert back to.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Christian
- SolopsistOct 17, 2020Aspirant
I just bought a refurbished RAX40, in anticipation of easy install and improved performance over my older NetGear router, which is now experiencing periodic drop-outs. At any rate, I too was afflicted with the dreaded inability to save configuration changes regardless of which browser I was using (Chrome, Firefox, Edge, Android browser). They all failed. I tried the android app first, and it got stuck in the saving configuration loop that was unending (assuming due to the Firmware). I was getting ready to have a lenghty conversation with Tech Support, when I ran across this article, and Rolled the Firmware back from RAX40-V1.0.3.80_1.0.1 (that it came with) to RAX40-V1.0.3.64_1.0.1 (the previous version). per the instructions in the previous post. This worked fine, and I can now save configuration changes.
Fix your buggy firmware, and for pitty's sake, test it before pushing it to the community. This is no way to retain loyal customers.
