larrys1111
Feb 27, 2021Aspirant
Unable to connect new RAX50 to internet
Cannot get internet connection on new RAX50. [Netgear tech was unable to help >3 hours] Am replacing a [working] old Linksys router. Am connecting to fiber service via wall plug. [no modem - cable ...
Christian_R
Mar 02, 2021NETGEAR Employee Retired
Hello larrys1111,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
larrys1111
Mar 02, 2021Aspirant
As I indicated in my post, the Netgear support tech was unable to assist after more than 3 hours. ALL new/old AC routers will connect to my ISP, NO new/old AX routers will. ???
- Christian_RMar 03, 2021NETGEAR Employee Retired
HI larrys1111,
May you send me a private message with your email address and case number(s) for me to better assist.
Thanks,
Christian
- larrys1111Mar 03, 2021Aspirant
larana726@sbcglobal.net
Netgear case# 44236092
- Christian_RMar 05, 2021NETGEAR Employee Retired
Hi larrys1111,
Thanks for the info. May you also send me a private message with your phone number and preferred contact time (including time zone) and I'll have support follow up on your case.
Christian
