HalBanger
Feb 10, 2022Aspirant
Unable to connect RAX40
Hi everyone, Like a lot of people, my router seems to have coonection issue. My scenario is : The router worked great for weeks, maybe even months. One day, I noticed my Iphone not being able...
Feb 10, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
- HalBangerFeb 11, 2022Aspirant
Hi and thank you for your answer.
The firmware is V1.0.3.94_1.0.1
The modem is a Spectrum Advanced Voice Modem EN2251.
My channel configuration is like that :
2.4ghZ : Auto
5gHz : 153
I switched the 5gHz to channel 48 as advised, but I can only chose one channel for each frequency, see screen shot attached.
I live in an appartment building so I have A LOT of other wifi around, like 30+.
So far since my last reset, everything works just fine. That's what have been happening this past months, after the reset, it works for a week or so and then the wifi issue come back.
Your help is appreciated,
- FURRYe38Feb 11, 2022Guru - Experienced User
If your in a wifi congested area, this may cause problem as to what your seeing, working after a reset then stops working. Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Really appreciate your help.
I changed the radio to 50% to both 2.4 and 5 GHz.
Hope this will fix it, I'll update here in a few days, thank you so much.
