stothjr
Apr 12, 2023Aspirant
Unable to Connect TIVO Roamio OTA to Nighthawk RAX29....
A few weeks ago I replaced my old Netgear R6700 WiFi Router with a Nighthawk AX2400 RAX29. All our devices connected to it without any trouble (I used the same SSID and router password used in my old...
stothjr
Apr 13, 2023Aspirant
Hi Michael...
I did look at these...but none were related to the problems I'm experiencing.
BTW....the TIVO Error Code I'm getting is a C206......NOT C26.
I finally heard back from TIVO. They sent me an email with the following info....
Which Network Ports and IP Addresses Need to be Open When Using my TiVo DVR?
Getting Started
Discover which ports must be open inside your router so that your TiVo DVR can access online services. Please be aware that there are many variations of routers, software, and settings that are unique to each computer.
The Outbound Port that needs to be opened in my router is Port 80.
According to TiVo Support, the service does not require any INBOUND access from the internet into the home network, but the TiVo box does require some OUTBOUND traffic to reach the internet and the TiVo service.
TiVo set top boxes and TiVo Desktop software must be able to access the TiVo service to enable features, access content, and perform updates.
I'm hoping you would be able to provide me guidance on how I would go about making this change in my router.
michaelkenward
Apr 13, 2023Guru - Experienced User
====================================================================I'm hoping you would be able to provide me guidance on how I would go about making this change in my router.
Until an expert steps in, I'd start with the Netgear manual:
Manuals are always a good place to start. Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
This really is something that TiVo should be able to answer. Its customers have a limited number of router brands to work with. About a half a dozen popular manufacturers.
Router makers will find it hard to keep up with the many thousands of devices their customers use.
