stothjr
Apr 12, 2023Aspirant
Unable to Connect TIVO Roamio OTA to Nighthawk RAX29....
A few weeks ago I replaced my old Netgear R6700 WiFi Router with a Nighthawk AX2400 RAX29. All our devices connected to it without any trouble (I used the same SSID and router password used in my old...
michaelkenward
Apr 13, 2023Guru - Experienced User
stothjr wrote:
TiVo set top boxes and TiVo Desktop software must be able to access the TiVo service to enable features, access content, and perform updates.
====================================================================I'm hoping you would be able to provide me guidance on how I would go about making this change in my router.
Until an expert steps in, I'd start with the Netgear manual:
Manuals are always a good place to start. Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
This really is something that TiVo should be able to answer. Its customers have a limited number of router brands to work with. About a half a dozen popular manufacturers.
Router makers will find it hard to keep up with the many thousands of devices their customers use.
Kitsap
Apr 13, 2023Master
Definitely not an expert.
A couple of configuration options, you might try testing with IGMP Proxy (enable/disable). Also NAT filtering (enable/disable).
- stothjrApr 16, 2023Aspirant
Hello Kitsap....
I'm responding to let you know that I'm not ignoring you/your suggestions and help. I've been distracted by "Honey Do's" that I need to get done.
As soon as I get those done, I will check out/try your suggestions; which are greatly appreciated!
- KitsapApr 16, 2023Master
stothjr wrote:Hello Kitsap....
Understand.....
