stothjr
Apr 12, 2023Aspirant
Unable to Connect TIVO Roamio OTA to Nighthawk RAX29....
A few weeks ago I replaced my old Netgear R6700 WiFi Router with a Nighthawk AX2400 RAX29. All our devices connected to it without any trouble (I used the same SSID and router password used in my old...
Razor512
Apr 15, 2023Prodigy
For the WiFi settings of the router, is the router using WPA3 or WPA 2+3 instead of just WPA2?
- stothjrApr 16, 2023Aspirant
Hi Razor512.....
Same response to you as well....I'm responding to let you know that I'm not ignoring you/your suggestions and help. I've been distracted by "Honey Do's" that I need to get done.
As soon as I get those done, I will check out and answer your questions. I do sincerely appreciate your help in resolving my issues.
