stothjr
Apr 12, 2023Aspirant
Unable to Connect TIVO Roamio OTA to Nighthawk RAX29....
A few weeks ago I replaced my old Netgear R6700 WiFi Router with a Nighthawk AX2400 RAX29. All our devices connected to it without any trouble (I used the same SSID and router password used in my old...
Kitsap
Apr 13, 2023Master
Definitely not an expert.
A couple of configuration options, you might try testing with IGMP Proxy (enable/disable). Also NAT filtering (enable/disable).
stothjr
Apr 16, 2023Aspirant
Hello Kitsap....
I'm responding to let you know that I'm not ignoring you/your suggestions and help. I've been distracted by "Honey Do's" that I need to get done.
As soon as I get those done, I will check out/try your suggestions; which are greatly appreciated!
- KitsapApr 16, 2023Master
stothjr wrote:Hello Kitsap....
Understand.....
