hwyman11
Aug 01, 2020Aspirant
Unable to connect to 2.4ghz wifi
After updating to RAX firmware ver 1.0.3.98 I was unable to connect 2 devices to the 2.4 wifi network. I only have 5 devices connected to the 2.4 network. 2 printers and 3 secuity cameras. I also tri...
Christian_R
Aug 06, 2020NETGEAR Employee Retired
Hello hwyman11,
May you perform a factory reset on the router and run through the setup assistant again.
Christian
hwyman11
Aug 15, 2020Aspirant
Resetting did not work. Rolled back to ver.1.0.2.76 and I am able to connect the deivces to the 2.4ghz. network. I beleive it has to do with the firmware. I even tried disabling AX but that di not help.
