ronald_fr
Apr 10, 2020Luminary
unable to disable WPS
Hello, according NETGEAR KB about it : https://kb.netgear.com/19824/How-do-NETGEAR-Home-routers-defend-WiFi-Protected-Setup-PIN-against-brute-force-vulnerability I unchecked the "Enable Route...
LSIMM
Aug 24, 2020Guide
Hi, I tried the same and it appeared to work, however the result of saving the new setting did not appear to show up, until I was timed out, then logged back in as admin again. Now showing "Not configured".
- ronald_frAug 25, 2020Luminary
Hello,
thanks for you response, but I don't understand : on my RAX40 I'm running 1.0.3.80 (it was same with previous release)
"Enable Router's PIN" is unchecked. Router has been rebooted some times, web admin has timed out a lot and nothing changes :
I always have "Wi-Fi Protected Setup Configured"
Best regards
Ron
- LSIMMAug 26, 2020Guide
From reading other forum posts it sounds like lots of bugs in various firmware versions, including the most recent, which I'm also on.
Who knows, hopefully they can sort out lots of these issues in the next release.
