ronald_fr
Apr 10, 2020Luminary
unable to disable WPS
Hello, according NETGEAR KB about it : https://kb.netgear.com/19824/How-do-NETGEAR-Home-routers-defend-WiFi-Protected-Setup-PIN-against-brute-force-vulnerability I unchecked the "Enable Route...
LSIMM
Aug 24, 2020Guide
Hi, I tried the same and it appeared to work, however the result of saving the new setting did not appear to show up, until I was timed out, then logged back in as admin again. Now showing "Not configured".
ronald_fr
Aug 25, 2020Luminary
Hello,
thanks for you response, but I don't understand : on my RAX40 I'm running 1.0.3.80 (it was same with previous release)
"Enable Router's PIN" is unchecked. Router has been rebooted some times, web admin has timed out a lot and nothing changes :
I always have "Wi-Fi Protected Setup Configured"
Best regards
Ron
