ronald_fr
Apr 10, 2020Luminary
unable to disable WPS
Hello, according NETGEAR KB about it : https://kb.netgear.com/19824/How-do-NETGEAR-Home-routers-defend-WiFi-Protected-Setup-PIN-against-brute-force-vulnerability I unchecked the "Enable Route...
ronald_fr
Aug 25, 2020Luminary
Hello,
thanks for you response, but I don't understand : on my RAX40 I'm running 1.0.3.80 (it was same with previous release)
"Enable Router's PIN" is unchecked. Router has been rebooted some times, web admin has timed out a lot and nothing changes :
I always have "Wi-Fi Protected Setup Configured"
Best regards
Ron
LSIMM
Aug 26, 2020Guide
From reading other forum posts it sounds like lots of bugs in various firmware versions, including the most recent, which I'm also on.
Who knows, hopefully they can sort out lots of these issues in the next release.
