jelsomino
Jul 30, 2021Tutor
Unable to load latest firmware on RAX80
Hi, Can't fine similar post so I'll create a new one. I checked firmware update for my RAX80 router and automatic system found a new 1.0.5.126 version (see attached) However when I tried to use...
- Jul 30, 2021
Thank for the suggestion but there is no new firmware file to download.
P.S. Problem solved by restarting the router and attempt to update using Nighthawk app for Android
Jul 30, 2021Guru - Experienced User
I would try manually updating.
I prefer this method anyway as a manual update over a hardwired connection tends to get the least "corrupt firmware" issues.
- jelsominoJul 30, 2021Tutor
P.S. Problem solved by restarting the router and attempt to update using Nighthawk app for Android- plemansJul 30, 2021Guru - Experienced User
Eitherway, glad to hear you were able to update successfully
- daweiduJul 30, 2021Star
New Firmware Version 1.0.5.126_1.0.65 Release Notes: 1. [Bug Fixes] Fixes minor bugs. 2. [Security Fixes] This firmware fixes security vulnerability issues. For more information about security vulnerabilities, visit netgear
