tholmes721
Jan 22, 2024Guide
unable to login to the web interface of my Nighthawk 5400
I can access my router from the nighthawk app on my phone, but its not letting me change some of my wifi settings, namely DNS ip's so I tried logging in through the web interface. At the login pr...
michaelkenward
Jan 25, 2024Guru - Experienced User
citiot wrote:
Same thing here with rax50v2. Tried multiple browsers, multiple devices.
For the third time of asking, what modem/gateway/ONT that sits between the RAX50V2 and the Internet?
We ask that question because it makes a big difference to how the router responds to things like login requests, especially if that connection is through a modem/router.
citiot wrote:
firmware v1.1.4.28
You have the latest firmware.
tholmes721
Jan 25, 2024Guide
Unfortunately I had to go out of town for work and have not had the ability to pull the model # of my surfboard cable modem.
I will be home this evening to pull this, however it seems odd that my laptop connected directly to the Nighthawk would pass traffic out to the internet, and back in again to bring up the web interface on a 192.168.1.1 device does it not?
When I get home this evening, I will test out a direct ethernet connection to the Nighthawk and disconnect the LAN cable from the cable modem to insure this isnt happeneing and see if the login works and report back.
