tholmes721
Jan 21, 2024Guide
unable to login to the web interface of my Nighthawk 5400
I can access my router from the nighthawk app on my phone, but its not letting me change some of my wifi settings, namely DNS ip's so I tried logging in through the web interface. At the login pr...
tholmes721
Jan 27, 2024Guide
Rebooted the Arris SB8200 modem, and the nighthawk router, waited for both to come back up, and tried again with unfortunately the same error:
"Access to the requested page has been denied."
and a URL with a serial number that does not match my device:
I went over to the my netgear page and noticed my router wasnt listed, which I could have sworn I registered when I bought it, because from the mobile app it says device registered, but when I attempted to add it to the my netgear page it says my serial # is registered to someone else?
Sent an email to netgear support, but no response so far.
I guess my last resort is going to be a factory reset to see if that resolves the issue
Feb 21, 2024Guru - Experienced User
Any progress on this?
Did the factory reset work? This fixes this issue on this version of FW:
