tholmes721
Jan 22, 2024Guide
unable to login to the web interface of my Nighthawk 5400
I can access my router from the nighthawk app on my phone, but its not letting me change some of my wifi settings, namely DNS ip's so I tried logging in through the web interface. At the login pr...
MrEli
Mar 16, 2024Initiate
Hi don't know if you solved this issue yet but for those who are looking for a possible answer here it is.
1. Disconnect Internet port.
2 Wait a few seconds (device needs to detect that internet is no longer available)
3 Connect computer via ethernet. (do not use a USB adapter it will most likely fail)
4 Clear cookies / cache ( you want to avoid reusing a bad login attempt)
5 Open Web browser http://"ip_address" (example: http://192.168.1.1)
- do not use "https://"
6 Enter credentials username: admin password: "your password"
Unfortunately the firmware has a bad "intrusion detection" rule.
Not much you can do to fix it but this is a workaround to access your router.
When you disconnect the internet cable the WAN rule set changed to LAN rule set
Hopefully this will be addressed soon in other models as well
