keithw7462
Feb 23, 2024Aspirant
Unable to login to the web interface
SAME ERROR MSG. BUT FOUND A WORK-AROUND to log onto router-
I AM able to log into RAX54 via any browser(Windows 11) if I unplug the INTERNET by unplugging my MODEM, a Motorola MB7420.
If I plug i...
- Feb 23, 2024
LOGIN WORKAROUND- UNPLUG INTERNET/MODEM
I found I could stop the error & Login by cutting off the router from the Internet- i.e. from allowing the router to talk to Netgear servers which for some benign reason return that same error message and with the WRONG S/N of my & other's routers.
Feb 23, 2024Guru - Experienced User
Yes, FR works to fix this on this version of FW:
- keithw7462Feb 23, 2024Aspirant
