Tomchu
Apr 01, 2021Follower
Unable to remotely download vpn client files from Nighthawk RAX75
From outside, remotly access my Nighthawk rax75 router. After login, then go to Advanced->Advanced Setup->VPN Services, click "For Windows" to download configuration files, it always pop up message b...
michaelkenward
Apr 02, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
