arodewald
Dec 26, 2021Aspirant
Unable to save port forwarding changes
Hello, I am trying to add a custom port forwarding service. Nothing happens when I click on Apply. The Apply button becomes disabled, but nothing will be changed. If I wait, nothing will happen and ...
Dec 27, 2021Guru - Experienced User
arodewald
Dec 28, 2021Aspirant
Thanks for the reply! I have not done a factory reset. I am away from home but will try that as soon as I can.
I also don't have a normal model. I have a line-of-sight service, so I have a small satellite that points at a nearby antenna.
