arodewald
Dec 26, 2021Aspirant
Unable to save port forwarding changes
Hello, I am trying to add a custom port forwarding service. Nothing happens when I click on Apply. The Apply button becomes disabled, but nothing will be changed. If I wait, nothing will happen and ...
Dec 27, 2021Guru - Experienced User
arodewald
Dec 29, 2021Aspirant
Thanks FURRYe38 - I was able to perform a factory reset today, however I am still having the same issue. You asked about the modem, but I'm not sure what to provide you since I do not have one. I just have a direct connection to a satellite that points at an antenna. I have a small local ISP using a line-of-sight service.
