NightHawkUser8's avatar
Aug 11, 2020
Unable to see 5ghz network
I'm unable to view the 5ghz network that I've setup on my RAX45. I have the 5ghz network setup with a different name than the 2.4ghz one and I do not have Smnart Connect on. I also have SSID broadcast enabled for the 5 ghz network. When I view available networks on my laptop or phone, my 5ghz network is not listed. Any ideas as to why?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Are you sure that these devices are 5 GHz capable? They won't see it if they can't use it? Do they work on 5 GHz anywhere else?
    Is the RAX40 set to broadcast all SSIDs?
    If you visit the support pages:
    Support | NETGEAR
    you can feed in your model number and find the documentation for your hardware.
