hecdtec
Oct 20, 2020Aspirant
Unable to setup DDNS
Trying to setup DDNS after choosing using the service, inserting hostname, email and password, check No I do not have an account and checking agreeing to the terms of service. I get a flicker and com...
- Oct 25, 2020
Found two things that had to be changed in order to get this to work.
1. I had to add the follwoing "-." to the NP-OP domain (ex. -.mydomain.noipdomian.suffix).
2. I had to remove the symbol from my NO-IP password making it only AlphaNumeric.
Hope this helps someone else in the future.
Christian_R
Oct 23, 2020NETGEAR Employee Retired
Hello hecdtec,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- hecdtecOct 25, 2020Aspirant
Figured out I had an account already when I went to NO-IP site and attempted to create an account. Set everything up but still can't get the Router to communicate with the NO-IP domain except when using the incorrect password or user accout. <scratch my head> Their is something seriously wrong the the Netgear DDNS client within the router firmware I believe bc of the wierd way this has been reacting to updating the NO-IP ddns server. I opened a ticket with NO-IP but if anyone know what is going on here I would appreciated.
