hecdtec's avatar
hecdtec
Unable to setup DDNS
Trying to setup DDNS after choosing using the service, inserting hostname, email and password, check No I do not have an account and checking agreeing to the terms of service. I get a flicker and com...
  • hecdtec's avatar
    hecdtec
    Oct 25, 2020
    Found two things that had to be changed in order to get this to work.
    1. I had to add the follwoing "-." to the NP-OP domain (ex. -.mydomain.noipdomian.suffix).
    2. I had to remove the symbol from my NO-IP password making it only AlphaNumeric.
    Hope this helps someone else in the future.
