WowMeEvents
Mar 09, 2020Star
Unable to update RAX80 Firmware, continued
I was asked to start a new threat, but I"m experiencing the exact same issue as this... https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Unable-to-update-RAX80-Firmware/m-p/1870828#...
WowMeEvents
Mar 09, 2020Star
what errors is it giving you?
It does not give me an error message.
where is it failing?
It is not 'failing'. It goes through the update process like I assume it should, but at the end (after the reboot), the firmware still shows the same version.
this helps more than just saying "it won't take". What's happening because we aren't there to see it. Take screen snips or better describe where/how/whats going on. There's multiple ways to update and describing how its failing in each is needed.
From what I understand, there are only two ways to update firmware (which technically is 'multiple') - 'check' or 'browse'. Is there another?
I've tried both. Neither one actually updates the firmware. It looks like it's updating the firmware, but it doesn't actually update it.
Helps me to help you.
I appreciate your help. What else can I tell you?
Mar 09, 2020Guru - Experienced User
Which version are you trying to manually upgrade to?
Not auto-update. but manual.
where you download the firmware, extract it, and then install it.
Make sure to do it over a hardwired connection for the best results. I'd also recommend resetting the router before you start. reason why is youre on a version thats 6 versions out of date. so do a factory reset-then upload the firmware.
Page 99 in the manual walks you throught the update. Again, make sure to extract it. many make that error.
- WowMeEventsMar 09, 2020Star
Yes, I know you can't update with a zip.
Yes i was using a hard-wired connetion to the router.
Rebooting screenshot.
I did reset it...software and hardware.
- plemansMar 09, 2020Guru - Experienced User
did you try factory resetting and doing the install?
I'd also recommend taking an intermediate step. See if you can upgrade to version .56 instead of going all the way to .70
