nyflfrank
Oct 28, 2021Follower
unable to update ssid or password on rax35 nighthawk router
Unableto have upate take for ssid or password on rax35 nighthawk router. Hnave rest to factory setting, rebooted. Hve tried update fron tablet, desktop, wifi and ethernet connections. Outcome always the same, change revert to previous setting,
Firmwarerax35 v1.0.3.94-1.0.1 Very frustrated. Previouly, fllowed same proceedure and work with no problem day later problem. Help, please be specific with instrustions not tech savy. Thanks
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Try a different browser or wired Pc to change the routers web page values.
Thank you. - FURRYe38Guru - Experienced User
You might contact NG support about this.
