Pepperheads6
Oct 10, 2024Aspirant
Unknown appa
Has anybody had any issues with unknown apps being blocked and not permitting them to be used? (Ie. Gamma IPTV)
michaelkenward
Oct 10, 2024Guru - Experienced User
What Netgear stuff are you using?
What are you doing and what happens?
Just another user with time on their hands.
- Pepperheads6Oct 10, 2024AspirantI’m trying to download gammaIPTV APP AND CONTINUOUSLY get an internal server error when trying to g to update and add app
- Pepperheads6Oct 10, 2024AspirantI use a nighthawk ax4200. Something is blocking me from updating the app after using it for 2 years
- michaelkenwardOct 11, 2024Guru - Experienced User
Pepperheads6 wrote:
I use a nighthawk ax4200. Something is blocking me from updating the app after using it for 2 yearsWhich one?
ax4200 is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
Updating how? What happens when you try?
This is the most reliable way to go about it:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
